2.060 visninger | Oprettet:
Niels J
Niels J
29. sep 2012
Følger: 1 Emner: 4 Svar: 19
(Forgaffel) Hvad betyder rake? {{forumTopicSubject}}
Haløjsa CG.
Står og skal bestille mig en ny forgaffel til raceren! Men opdager at der er to forskellige slags en der hedder 43mm rake og en der hedder 45mm rake, har ingen ide om hvad det betyder...! Nolge her inde fra der skal fortælle mig det?
Så ville jeg bare blive sindsygt glad hehe smiley
På forhånd mange tak!
Hilsen Niels J.
  • Sætte 2 lamper op 500 kr.
  • Fallen dryer blocking entrance into bathroom 2.000 kr.
  • Reparation af sage espessomaskine 1.000 kr.
  • Flydespartel 1.500 kr.
  • Montering af låge på intregreret opvaskemaskine / Siemens 1.540 kr.
  • Ukrudt fjernes 1.200 kr.
Kommentarer på:  (Forgaffel) Hvad betyder rake?
  • #1   12. mar 2013 Offset
    Bicycle forks usually have an offset, or rake (not to be confused with a different use of the word rake in the motorcycle world),[1] that places the fork ends forward of the steering axis. This is achieved by curving the blades forward, angling straight blades forward, or by placing the fork ends forward of the centerline of the blades. The latter is used in suspension forks that must have straight blades in order for the suspension mechanism to work. Curved fork blades can also provide some shock absorption.
    The purpose of this offset is to reduce 'trail', the distance that the front wheel ground contact point trails behind the point where the steering axis intersects the ground. Too much trail makes a bicycle feel difficult to turn.
    Road racing bicycle forks have an offset of 40-45mm.[2] For touring bicycles and other designs, the frame's head angle and wheel size must be taken into account when determining offset, and there is a narrow range of acceptable offsets to give good handling characteristics. The general rule is that a slacker head angle requires a fork with more offset, and small wheels require less offset than large wheels.
    Fork offset influences geometric trail, which affects a bicycle's handling characteristics. Increasing offset results in decreased trail, while decreasing offset results in increased trail.
  • Niels J
    Niels J Tilmeldt:
    sep 2012
    #2   12. mar 2013 Er ikke ret god til Engelsk, og køre man det igennem google translate er det aldrig til at forstå.. Nogle der kan forklare mig det på Dansk? smiley
    På forhånd rigtig mange gange tak!
    Mange hilsner Niels J.
  • #3   12. mar 2013 Det er hvor langt fremme akslen sidder iforhold til gafelstilken. 43 er mest normal og 45 er lidt mere comfort smiley det var den korte udgave min forklaring
  • #4   12. mar 2013 Arh Jonathan, du burde være ekspert i det her! smiley skal du ikke til svendeprøve nu her?
    Rake eller fremspring er hvor langt dropoutet (akslen om man vil) sidder væk fra den linje, der ville komme, hvis du tegnede en linje langs med kronrørsvinklen og gennem forgaflen. Altså følger forgaflen ikke kronrørsvinklen, men har et fremspring på typisk omkring 43mm...
  • #5   12. mar 2013 Ja men tænkte folk stod af hvis ejg forklarede det ligesom jeg plejer at gøre med ting i klassen smiley og jo det imorgen
  • #7   12. mar 2013 Held og lykke med det smiley
